This is the top of a ball joint on a dana 44 knuckle. Any one know how to get this SOB out?
18derrick · Registered Joined Oct 18, 2005 · 187 Posts Discussion Starter · #1 · Jan 23, 2007 Only show this user This is the top of a ball joint on a dana 44 knuckle. Any one know how to get this SOB out?
M mr4x4 · Registered Joined Sep 30, 2006 · 1,241 Posts #2 · Jan 23, 2007 Only show this user make sure you replace both top and bottom at the same time then you might as well do the other side to its off a ford but should help http://www.off-road.com/ford/bigbroncos/tech/balljoint.html
18derrick · Registered Joined Oct 18, 2005 · 187 Posts Discussion Starter · #3 · Jan 24, 2007 Only show this user I found a tool to remove it, its called a ball joint spanner wrench. 22 bucks and I had to hunt all day to find one.
