Hi everyone - does anyone have the default settings for the BT field?
I was troubleshooting a bt/wifi issue and changed the settings.
My head unit can see my phone, but not the OBDLink LX I have. It sees it as available, but I can't select it to pair.
Thanks,
Jerry
That happens to me with the PX5 and the Vlink odb BT adapter. The little OBD indicator icon at the top of the screen is a dotted line. (I assume the dotted line indicates the adapter is there but not paired)
What I have to do is first "start Bluetooth" with an app called DEVICE INFO. Under the test section of the app there is a TEST Bluetooth option. Click on it and it will say "starting bluetooth". Give that a minute or so then you can kill the app. The odb adapter, at that point (for me anyway) is now online and can be used. The little obd icon at the top has even brightened up and changed to solid lines.
It's a bit of a pain in the ass, which is why I no longer use BT for the torque app that I run. Torque is set up to start automatically on start up and it was always a pain to get the BT up and running so now.
The torque (pro) app works with Dasaita and a usb connection which is what I use.... for torque anyway. The connection is immediate and rock solid. My BT connection is only used now for OBD Jscan which I don't use all the time.
https://play.google.com/store/apps/details?id=com.ytheekshana.deviceinfo
The other thing you need to do is make sure your BT PIN number is set for 1234 and not 0000 (most obd adapters have a default pin as 1234)
