After trying two separate single- DIN stereo install kits, I've not been happy with either. Tried a cheap eBay kit and one from the local stereo shop and neither seem to fit tight and flush with the dash bezel.
Anyone have any kits that they've had good success with? Also, anyone else have problems with the dash bezel fitting a little loose at reinstallation? (I've got some gaps around climate control panel and at the top near the defroster register and small pad area)
I have a slight gap on mine. If you can post some pics we can get an idea of how far off yours is and see if it is any worse than all the others. Also make sure your mounting bracket is not in upside down or backwards
