I need to remove the dash to fix defrost damper that won't open due to broken plastic piece. I have removed all screws that I can see. The dash is getting hung up around the area of he airbag. I stopped at this point cause I dont know if the air bag will pop out or I damage it. I don't see anymore screws. So instead of taking a hammer to it I will check here first
there are a few pretty detailed write ups on this there are two 10mm bolts that have to get removed up under the airbag cover get a ratcheting wrench
Thanks for the info guys. Last thing I wanted was a face full of airbag.
