07 2dr upsized tires 2 mo ago and soon after got warning lights for ABS, brake and trac control. also noticed left front tire seems to drag after start up on loose dirt. no cruise cont. searching web brings up wheel speed sensor or ABS sensor...any other ideas or tips?? thx guys
Some times it is just loose connects on the battery. Check those and make sure they are tight. I hope that is it as it is an easy thing to check and correct.
If that is not it then it is likely the wheel sensor I think it is a common problem.
It is possible that the wheel bearings are worn. I had all of those symptoms at around 150k and I had the hubs replaced and all is well.
