You said it shook between 50-55. If it is being felt in the steering wheel, it is almost certainly your tires...either badly worn or out of balance. But from the way you described it, It sounds like your engine is shutting down. If that is the case and there is no vibration in the steering wheel it sounds like it might be an electrical or fuel problem that is making your engine shudder.
