Mostly old school..!
Do a dry steering test to determine why.
Dry Steering Test
Do a dry steering test by having someone sit in your Jeep (with the tires on the ground) and continuously turn the steering wheel back and forth from about the 11 to 1 position while you lay under the front end and watch and feel for any lateral play in any steering or suspension joints. Check both track bar ends, the tie rod and drag link ends.
Although rotational movement in the tie rod and drag link is normal and necessary, there should be no end movement at all in the joints. There also should be no movement in the track bar ends.
