1 - 9 of 9 Posts
Hey everyone -
After deciding... and re-deciding... and re-deciding... I think I've landed on the following (with a few questions I could use your help with):
Option 1: 285/70/R17 BFG KO2, Mammoth Boulder Wheels in Black, No Lift, Stock Fenders
Option 2: 315/70/R17 BFG KO2, Same Wheels, Lift, Stock Fenders
My questions here are:
1. Will the Tereflex Performance Leveling Kit be enough to avoid rubbing with stock fenders? Or does it make sense to go up to a 2-2.5in lift?
2. Will I need to update my tire carrier?
3. What am I missing?
What do you think overall? I really like the look of both options. For reference, its a 2015 white 2dr JK.
Andrew
The stock tailgate tire carrier is rated for 85lbs. Check what the weight of your new wheel/tire combo will be before you make a decision
what gearing do you have. I think 315/70-17 with just a leveling kit will rub like crazy offroad.
Need a 2.5" lift with at least 2" bump stops to run the 315's with stock fenders... Not to mention a re-gear.
Reactions: HoustonHeathen
Commercial Member
True Thing!
I have a Teraflex 2.5" lift, and I rub my 33's (285/70R17's) on my fenders when offroading. They don't rub during turns because of my backspacing, but they DO rub when flexing over obstacles, or as I leave a steep decline. I'll be going to flat fenders soon to get a little more clearance.
Discussion Starter #6
To be honest I'm not sure what gearing I've got... easy way to calculate? If it helps maybe you could tell me?.. it's a bone-stock 2015 Sport.
Yeah I'm debating between taking the plunge with the 35"s and all that come with it.. or going 33"s with no lift. I think i prefer a look without a ton of spacing between the top of the tire and the fenders..
That being said after looking at a million jeep pics who knows what I want anymore :)
Commercial Member
Well, if it's a street vehicle only, you might be able to get away with 33's and no lift, but you'd probably want a good bump stop at least. If it's an automatic sport, you probably have 3.21 gears. I do too. It's workable with 33's, as long as you don't expect a lot of torque out of your tire! You will want to re-program your computer, with a flashpaq (sp?), or something like that.
If you don't offroad, you might be okay with 3.21 forever on the 33's. Just kind depends on what kind of peppi-ness you like from your jeep. To find out for certain about your gearing you can input your VIN somewhere on the Jeep website, I think and it will give you a detailed breakdown of how it was configured when it was originally sold.
I'll be re-gearing when I get my 35's near the end of the year.
After you figure it all out, post some pictures, and tell us what you decided on!
Cheers!
Discussion Starter #8
Well, if it's a street vehicle only, you might be able to get away with 33's and no lift, but you'd probably want a good bump stop at least. If it's an automatic sport, you probably have 3.21 gears. I do too. It's workable with 33's, as long as you don't expect a lot of torque out of your tire! You will want to re-program your computer, with a flashpaq (sp?), or sojmething like that.
Cheers!
Hey man! Thanks for the response! Its actually a manual .. not sure how that effects the gearing/need to regear with 33s.
I'm a beach bum so the Jeep will hit the sand a lot with some light off roading.. no rock xrawlinn or anything though.
Commercial Member
I think manuals might be 3.73 ratio, not sure if only some are, or if all are.
My wife loves the beach, so we are there all the time. We have a hella fun bombing through the mud flats and so forth. Haven't felt any need to re-gear so far.
Here's a video of us at the beach on 33's with our stock gears:
Here is a link to look up your original build:
https://fcacommunity.force.com/RAM/s/equipment-listing
put in your VIN, using capital letters and it should tell you how it was when it was delivered to the dealership.
1 - 9 of 9 Posts
