2003 TJ stock suspension. Just recently started hearing a slight knock when I hit uneven road. Coming from the front driverside area. It sounds like a suspension issue but everything looks shipshape under there. Today I jumped on my door sill and gave her a heavy rock to see if I could hear it while stationary. Nothing. It only seems to act up when I am underway. I can feel it in the pedals if that helps. Ideas?
Yeah thats probably sway bar bushings. They are inder the plastic cover up front thAt says jeep. Exctly same prob as me a while ago.
Check your exhaust over too...it moves around alot when underway. Sometime a broken weld or hanger will cause to bang around.
It was the sway bar endlink on the driver side. Thanks for the help fellas!
