Here's a tip to use AFTER you make sure the bolts are properly torqued.
Take a paint marker and make a strip across the top of the bolt, down the side and end on the bracket. Thereafter you can do a quick visual check to see if the bolt is still tight. If the mark on the bolt is still lined up with the mark on the bracket you should be good. If the marks don't line up, the bolt has moved and its time to investigate further.
