Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
262709 Views 683 Replies 212 Participants Last post by  Nemo Consequentae
The videos are kind of long at 18-19 minutes each. Hopefully, they are thorough enough to help.
Death Wobble Diagnosis and Inspection Jeep JK Wrangler Part 1 - YouTube
Death Wobble Diagnosis and Inspection Jeep JK Wrangler Part 2 - YouTube
Inspection Checklist is in Post #2.
I'll start out by explaining that Chrysler decided to use a 14 mm trackbar bolt, with a trackbar bushing sleeve designed for a 9/16" bolt, and the trackbar bracket bolt holes are somewhere around 15-16 mm large. This is a sure recipe for DW if the trackbar bolts are not properly torqued and periodically re-torqued to 125 ft. lbs.
Death Wobble is no mystery.
It is caused by loose bolts, damaged components, or improper
installation.
Look at the picture below and follow along:
First, the tie rod (green) has ends that attach to a knuckle on each side. As you could imagine, if either ends of the tie rod were broken or bad, that could be a culprit for a shimmy (not Death Wobble). A common place to damage the tie rod is on the driver's side at the adjusting sleeve (in the picture, just to the right of the red swaybar link). That sleeve (maybe not the correct term for it, but you can see what I am talking about) allows the width of the tie rod to be expanded or contracted. There are threads on that end that can be damaged, causing play on that driver's side and allow an up and down, or circular play movement. Again, this would cause a shimmy, not Death Wobble.
Next, look at the drag link (purple). On one end, it attaches to the pitman arm (lavender), that attaches to the steering gear box. On the other end, the drag link attaches to the passenger side knuckle. When you turn your steering wheel, a shaft turns that goes to the steering gear box. The steering gear box turns the pitman arm, and the pitman arm pushes or pulls the drag link, which pushes or pulls the knuckle. Your steering wheel is straitened by loosening the two nuts on the sleeve/turnbuckle on the drag link and rotating the sleeve/turnbuckle to lengthen or contract the length of the drag link. If either end of the drag link is damaged, this would cause a wobble or shimmy, but not Death Wobble.
Next, look at the trackbar (aqua). It attaches to a bracket on the frame on the driver's side and to the axle on the passenger side. The purpose of the trackbar is to center the axle on the frame. With the axle centered on the frame, it provides some resistance to the steering system to allow you to turn. If there was no trackbar and you turned the steering, the whole front frame would shift. As a result, there is significant force applied to the trackbar in driving and steering.
Now, imagine that the bolts that hold the trackbar are loose in their bolt holes, or that the bolt holes are wallowed out (oval), or that the bushings at the trackbar ends are damaged, or that the bracket at the axle side has come loose because the weld has broken, or that the bushings are all twisted up because the rig has been lifted without the installer loosening the bolts and then retightened them at the new ride height. All these things would allow play in the front trackbar. When you steer or go around a corner, these loose or broken things would allow the axle to shake or slide side to side. If you hit a bump in the road, it could knock the trackbar towards the driver's side. Then, the rest of the suspension (springs, etc.) would try to bring the trackbar back to the passenger side. If you were going at any sort of speed, you could develop a kind of harmonic resonance as the axle more and more violently slide/rocked/shaked from side to side. It would feel like your whole front end was being voilently torn apart. You would have to bring your vehicle to a complete standstill to stop the harmonic resonance. This is Death Wobble.
Even one incident of violent Death Wobble related to the front trackbar can cause significant damage. The voilent harmonic resonance of the back and forth shaking is more than the trackbar bushings, bolt holes, and brackets are designed to handle. A severe Death Wobble occurance can crack or break the welds on the axle side trackbar bracket, or the bolt can wallow out the bolt hole in the bracket, or the bushing can be permanently damaged.
This is the most common source of Death Wobble because inexperienced installers either do not remove the bolt from the trackbar when they install a lift--leaving the bushing pinched in the bracket and bound up, or they do not properly torque the bolts after the lift has been installed with the tires on and the full weight of the vehicle on the ground at ride height, or (maybe the most common) they do not retorque the trackbar bolts after the first 50 miles, after every heavy wheeling trip, and at every oil change interval.
Next, look at the lower control arms (purple) and the upper control arms (light blue). In the picture, they are aftermarket arms with a heim joint on one end. However, the stock control arms have a rubber bushing at each end. When the control arms are properly torqued, the bushing is somewhat pinched in the mounting brackets on the axle and the frame. Sometimes, an installer will make the mistake of not loosening the bolts for the control arms when they install a lift. What happens sometimes is they really bind up the bushings because they are pinched/sandwiched at stock ride height, but then forced to the new lifted ride height. These bound up bushings can cause weird handling, bushing failure, and lead to Death Wobble. The proper way is to loosen the bolts, install the lift, reinstall the wheels so the suspension and jeep are at the new ride height, rock the vehicle/suspension back and forth and side to side, then re-torque the bolts to spec, then after 50 miles re-torque them to spec, then after every oil change or very heavy wheeling trip re-torque them to spec.
Improperly balanced tires, too much air in tires, bent wheels, improperly installed wheel spacers, bad tires (with separated plys), and poor alignment specs (caster, camber, and not enough toe-in) can cause wobbles and shimmies that lead to Death Wobble. However, these precipitate Death Wobble, but they are not the cause of Death Wobble.
Although not specifically identified in the picture, the ball joints that are at the top and bottom of each knuckle where it attaches to the axle C can go bad. Bad ball joints can cause shimmies, wobbles, but usually not full on Death Wobble.
Next, allthough not identified in the picture, the unit bearings can go bad and be a cause of shimmy and wobble, but not Death Wobble.
Hope this helps--assuming you read it all.
The reason that the steering stabilizer masks it is that it can absorb some of the side to side voilent harmonics of a loose trackbar or damaged mounts. However, this masking is dangerous because it will not prevent the eventual failure of trackbar bracket welds and bolt holes from trackbar Death Wobble.
It is extremely important to immediately diagnose and fix Death Wobble.
Even one episode of DW can damage other components.
Multiple episodes of DW are almost guaranteed to damage other components.
Multiple episodes will often damage your:
    • ball joints
    • tie rod ends--including the adjusting sleeve end on the driver side
    • trackbar bushings
    • trackbar bracket bolt holes
    • steering sector shaft (where the pitman arm attaches to the steering box)
    • steering stabilizer
    • front lower control arm bracket bolt holes
    • unit bearings
    • trackbar bracket welds
    • drag link ends
Hellbound13 is an example of a member who with 5-6 episodes of trackbar related DW on a stock jeep ended up "chasing his tail" for many, many months. He ended up replacing almost everything in the above list--sometimes more than once.
Without repairing/replacing everything that was damaged at once, the remaining damaged components continued to cause DW problems, further damaging the remaining components.
This is Death Wobble (and the guy is extremely foolish for repeating it on purpose):
YouTube - Death Wobble
Reactions: 5
81 - 100 of 684 Posts
planman said:
As I mentioned in post #1, Chrysler decided to cut corners and uses bolts that are too small compared to the front trackbar bracket bolt holes and bolt sleeves.
They should do a recall of all JKs and install 9/16" front trackbar bolts.
Is there a reason we as consumers can't (or shouldn't) simply do this as part of a lift install or general maintenance?
I recommend using 9/16" bolts for the front trackbar for every lifted JK or stock JK that has had DW.
What caster correcting gear was used in the lift? Have you had the caster checked since installing the lift? What wheels/tyres and offset do you have?
Downunder Dave,
Thanks for the reply, I used no caster correction gear but I did have the alignment checked by a front end shop after the install. I did not however loosen the track bar and control arms during the lift install. Today I loosed everything as recommended and removed most components for a visual inspection. The death wobble only occurred once and appears there is no component damage. Everything was reinstalled and torqued to spec. For now the wheels and tires are stock 17" with goodyear P255/75R17 wrangler tires. The lift is a 2.5" Rough Country spring and 3/4" bushing lift with n2.0 shocks.Would it be wise to replace the 14mm trackbar bolt with a better fitting 9/16" bolt? Thanks Again and will keep poted on further developements.
jkclyde
Omg dw!!
DIAGNOSIS CHECKLIST
Assuming your tire psi is 28-30, your tires/wheels have been balanced and rotated to make sure the wobble doesn't move with the rotation, here would be my order:
  1. Remove the steering stabilizer.
  2. Have someone turn the engine on and turn slowly from full lock to full lock while I visually, manually (with my hands on the components), and auditorily inspect for any play in the tie rod ends, drag link ends, sector shaft, trackbar ends/bolts/brackets, and trackbar bracket welds.
  3. Then, do the same thing but with short, sharp, quick back and forth turns of the steering wheel between the 10 o'clock and 2 o'clock positions, instead of the slow, lock to lock approach.
  4. Then, I would remove the front trackbar to inspect the bolt holes for ovaling and inspect the trackbar bushings for separation or cracking with a long screw driver through the bolt sleeve and the trackbar in a vise to leverage against the bushing in all directions. If all is good, I would reinstall the trackbar with the tires on the ground at ride height to 125 lbs.
  5. Then, I would inspect the drag link end joints by using a large channel lock wrench that gave me enough leverage to check for up and down play in the drag link ends. There should not be any meaningful up and down play. If there is, the ends should be replaced, or a new drag link with heavy duty joints should be installed. After, I would check the torque of the drag link ends. Taller lifts magnify the problems of bad drag link ends.
  6. Then, I would inspect the tie rod ends with the channel lock wrench for up and down movement. There should be no meaningful up and down play. There should only be rotational movement in the joint end.
  7. Then, I would put the front axle on jack stands with the tires about 2" off the ground and check the front ball joints by using a long pry bar as a lever under the front tires to lift them up to inspect for up and down play in the lower ball joints. There shouldn't be more than maybe 1-2 mm.
  8. Then, I would use the prybar/lever against the frame and the top of the tire to inspect for lateral movement of the top ball joints. There shouldn't be any. If you have a lighter tire/wheel combo, you can do this by hand.
  9. Then, I would remove the front tires/wheels and remove the front tie rod--one knuckle at a time. Then with a large wrench or vice grips, I would inspect the end for side to side play. Then I would reinstall the end and torque to spec and repeat on the other side.
  10. Then, I would remove the brake calipers and brake disks to inspect the unitbearings for play.
  11. Then, I would reinstall the discs, brake calipers, and tires/wheels and set the axle back on the ground.
  12. Then, I would support but not lift the front axle with a floor jack and loosen the front lower control arm bolts. One at a time, I would drop the lower control arms to inspect the bolt holes and bushings (similar to with the trackbar), reinstall without torquing, and do the next one. Afterwards, remove the floor jack so the suspension is at ride height, vigorously rock the vehicle side to side and front and back, then torque to spec.
  13. Next, I would inspect the sector shaft that comes out of the steering box for cracking or twisting.
  14. Then, I would take a test drive without the steering stablizer to feel for any wobbles.
  15. Finally, I would reinstall the steering stablizer or spring $40 for a heavy duty steering stablizer.
If this front end inspection does not diagnose and/or solve it, then I would move to an alignment.
  1. I would use adjustable lower front control arms to set my caster spec between 4 and 5 degrees--with a cross caster that has less on the driver side than the passenger side. I would personally not do more or less, with a target around 4.5-4.7 degrees caster.
  2. If my camber is out of spec, but it is not due to failed ball joints, I would install offset ball joints to get my camber in spec.
  3. I would set my toe-in to spec on the machine--which is about a 1/8" toe-in.
  4. If my front to rear alignment is off, I would install rear lower adjustable control arms to fix this.
With all this, I highly doubt you do not find the source.
The last ditch thing if there is a non-DW, speed dependent range wobble, I would borrow a different set of wheels and tires to see if it changes, and I would try driving it with no front driveshaft to see if that changes anything.
Although it is always a good idea to inspect your axle shaft u-joints, they will not cause DW.
The most common sources of full on DW are:
  • Improperly torqued trackbar bolts
  • Damaged trackbar and control arm bushings because bolts were torqued on a car lift or while the vehicle was not at ride height with the tires on the ground. When you torque trackbar and control arm bolts, the bracket pinches the bolt sleeve in the bushing, as well as the bushing itself. If this is at a geometry other than actual ride height, the bushings are twisted/bound/pre-loaded, and they will eventually fail/separate/etc. If you have a flex joint end, this does not apply for that end.
  • Ovaled out trackbar bracket holes due to DW episodes from loose bolts.
I just had a case of this on the freeway. I was a lunch with a coworker and we were not going much faster that 45-50 on the freeway and the front end just went crazy. I couldn't stop it from happening but just let the Jeep slow down until it stopped. Breaking did not help the situation at all. I was so scared I nearly lost my nice lunch. It's going in the shop tomorrow AM first thing.
Kind of disappointing as I told the salesman when I bought the jeep please check the front end, there is a slight shimmy in the front end at high speed. They thought it was a balance and wheel alignment that needed to be done and I thought I would get that done next week.
CRAP!!!
Jk Death wobble
2010 JK with 5000klms on the clock ,, recently experienced horrific "Death Wobble" . Never heard , or experienced it in over 40 years of driving , and over 40 different vehicles.
Took it a dealer, was told they could find no evidence of a problem .I asled them to check the front end , and especially for the upgrades I had heard of .
They cam back , told me there was a slight wheel alignment problem , and one wheel out of balance.
I called Jeep Australia, they were not interested.
I have the Jeep back , and though it seems to be driving ok ,I back off a lot , and get a bit concerned when passing or being around other vehicles, as it feels like it's ready to do a repeat performance at any tick of the clock .
Sought legal advice , was told if I have an accident due to this , I will be held responsible .
Wrote the problem up on CarAdvice, a website for car probs.
Got an E-mail from Chrysler asking me to call them .
Sent a reply stating as there were not interested when I called , and as they are prepared to sell vehicles like this , I doubt very much I'd get any help from them .Told them not to bother replying.
Am now seeking legal advice as to how I stand re My financial contract , as I'm looking to get rid of it , as no confidence, and don't fancy driving another 4 years wondering if I'm going to land in Jail.
Also seeking advice as to the roadworthiness , and how it managed to pass.
Will post more.:banghead:
I am so sorry for you trouble. See my thread "the verdict". I would not give up and keep trying to get your situation resolved.
Thanks for that , good to see you had a win , hope it works out well for you . That was a nasty one.
Cheers,, I'll keep trying.
Read posts #1 and #2 of this thread.
It has most all the information you need to fix the problem.
Do not drive your jeep anymore until you fix it.
I totally agree not to drive the Jeep anymore until it is fixed. I hope you an get your Jeep fixed soon. I'll say some prayers to the car gods for you. ;)
Dw sucks. All i have left is a small amount of shimmy that i can't find.
Is it speed dependent or random?
Can you drive out of it by going faster?
How even is your tire treadwear?
Its more of a small shimmy after hitting a really upsetting bump. Other than that droves perfect. I use to have dw out of no where. Did an adjustable track bar and it was gone.
Well, not going to get any help from chrysler, unless I drive around the country to a dealer,, so looks like I'm on me pat malone,, last jeep for me ,, cheers folks ,, thanks for listening
It really isn't that hard to fix.
Might be if you have the right gear and the know how ....
That is true, but it is not rocket science, and it doesn't cost more than maybe a couple hundred dollars to buy the right gear.
What you need to do the inspection:
Jack stands
torque wrench that goes up to 150 ft lbs
ratchet and socket set with some extensions
15, 18, 19, 21, 22 mm wrenches
floor jack
channel lock pliers
pry bar
As far as the know how goes, if a person prints off the picture in post #1 and follows the steps in #2, they shouldn't have too hard of a time checking things.
The primary sources of DW are trackbar related. It really doesn't take much know how to remove the front trackbar to inspect the bolt holes for ovaling, and then reinstall it with 9/16" grade 8 bolts instead of the stock 14 mm bolts.
It really doesn't take much know how to have someone cycle the steering left to right while you lie under the front of your jeep and look/listen/feel the tie rod, drag link, pitman arm, and trackbar for clunking or loose ends.
Even if that is too much, most areas have a local 4x4 club with members who are more than willing to help a fellow jeeper figure things out. Many local clubs have "Mod Days" where they get together to do modifications and upgrades at the same time.
Thanks planman, just had a chat with the dealer, think I know more than he does:)...I asked him if he'd experienced a death wobble ,, he couldn't give me a straight answer,, said he would discuss it with others at a meeting later in the week..
Think I'll go buy some more tools :punk:
With an answer like that I would definitely be looking at your own tools or a local club!
But then its not an unexpected answer, we get the same blank stare from dealers down here when asking them the same question.
It could be that a lot actually know what you are talking about, but a little thing called deniability creeps in and creates the blank response....
I am in the middle of having my JKU fixed forthis DW issues (pretty scary stuff when it happens at 60 MPH). I printed out artcle#1 and #2 for the dealership to follow. BUT.. that being said, once they give me back my JKU, I am taking to a mechanic that my local club has recommended and having them do the same check posted to ensure everything that should have been fixed is/was. I told the GM of the dealership, I will not sign off on the repairs until I am satisified that is truly is corrected. One thing I did notice is that the tires should probably be checked and for sure one replaced. (I'll probably change all 5 tires). The drivers side tire has a plug in it on the wall of the tire on the inside. I didn't notice that before until last week when the Jeep was jacked up on the lift. I don't think that is safe.
It's till in the shop and has been since 11/11. I'm in a rental (Ford Escape) since and missing my bigger ride. UGH!! But if it was not for this forum, I would not have known what the problem is and what to instruct the dealer to look for. Thanks Guys! YOU ROCK!
Have they kind of ironed-out this death wobble thing on the 2012 Jeeps?
I plan on ordering a new Wrangler in February with delivery in late March or early April 2012. It's going to be fairly basic - the Sport S, two-door with the 6-speed manual and dual-top option.
I don't do a lot of my own mechanic work on a car. I plan to use this as a daily driver (second car) and will occasionally drive it on backroads in North Carolina's mountains or make a few trips to the Outer Banks and may have it on the beach ...
Question: I had never heard of Death Wobble until today ... and it sounds pretty freakin' awful. Most of the posts I have read describe 2007-08 JKs. Does this continue to be a problem for the newer JKs?
