ok so i have a 1997 sport. its a 5 speed and i use it for plowing. ive never had any trouble untill this damn huge snow storm this weekend. i had it pushin alot of snow and i started smelling a funny smell.then she dies on me. and wont start back up. i run in my house thinking i broke somethin and then 30 min later it starts back up. this happend to me 2 more times and both times it took at least 15 min to start back up. any ideas?
Jeeper
Describe the "funny smell".... Sounds like you burnt something up..... But then, I have no clue about such things.
im not sure how to describe a smell.... it smells like somethin burning. i am also leaking some neon yellow stuff from underneath i noticed as i was digging myself out of some snow. everythings frozen underthere so im not sure where its commin from
Sounds like you are leaking antifreeze. Check it for leaks, sounds like the engine maybe overheating, reason for something burning smell and won't start until it cools back down.
Does the engine malfunction light come on? I have had a similar problem without the leaking fluid. It could be a crank angle or cam sensor! If so it's not too serious just an inconvenience. But the fact that it is leaking can point ton something a bit more severe?
I have run in to similar problems when I will go on snow runs and while plowing the trail for everyone. Sometimes you will pack enough snow in your radiator that it will stop cooling because it has no airflow. Granted you had a snowplow other than your front bumper like mine was, but that may have something to do with it. With the information provided, that would be my best guess... That you have an overheating issue due to lack of air flow..
so is there some sort of temp safety shut off? and i am always eyeing my temp gauge. it it was never above normal when it died. although it tends to overheat on the highways with the plow on it.and twice i redlined it but barely. anybody blow anything that quick before? it never did without it on so im guesing its a lack of airflow throught the radiator or maybe a thermostat. any ideas of how to fix that? my fluid levels are fine so its not a fast leak.
