Sponsoring Vendor
Jeep JL Wrangler Backup LEDs
http://www.youtube.com/watch?v=ibH55oB_yyU
Here's a great way to upgrade your Jeep JL Wrangler's appearance and safety at night. Diode Dynamics LED replacements are a great addition to any tail light, and can be easily installed, plug-and-play with no resistors needed. Huge upgrade when used with JL Wrangler backup cameras!
Diode Dynamics offers the brightest, most reliable, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs were designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits your JL Wrangler's output needs best. These options are listed by the design and the lumen output of each bulb:
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
The bulbs use an exact terminal and will fit as a replacement for JL Wrangler's stock incandescent. Diode Dynamics LED bulbs use less power and heat than the stock bulbs, and will last longer than your JL Wrangler. Diode Dynamics' LEDs use only the best components and are of the highest quality. The bulbs are designed for exceptional heat dispersion, and a diode is implanted to protect the LED from reverse polarity or voltage surge. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS to fit your Jeep JL Wrangler. This product is for Jeep JL Wranglers not equipped with the LED Lighting Package.
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: Backup LEDs for 2018+ Jeep JL Wrangler
Any questions, feel free to ask via email ([email protected]), Post, shoot us a PM! or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
