So bought some aftermarket headlights w/day running halos. Here's my issue. With the JK the freaking headlights come on automatically no matter what setting you have it on, once the vehicle is out into gear. I currently have it on automatic, but because my front windshield is fully tinted I believe it may be causing the sensor on the dash to think it's just dark enough causing the headlights to stay on during the freaking day :rant: Is there anyway to disable them so I manually have to turn on/off the headlights? I've disconnected the sensor at the dash location but that didn't work, probably thinks it's dark all the time lol, smh.... bottom line is I would like my halos on by themselves during the day as intended..
Wait, you have your windshield tinted? Sorry to stick on that...I want to live where you do if that's legal.
i think a flashcal can program the daytime running lights.
you can in FL w dr note
Freaking Florida. Okay. It may be here as well with MD note (no clue), but wouldn't be worth the constant harassment from DPS. Those dudes have a hard on for window tint. Back to your scheduled programming.
Headlights. The auto headlights on my jeep have options. Off, on, automatic...
Then regarding DRL, flashcal does a great job of customizing that.
You have to disable your DRL (Daytime Running Lights) using a Flashcal programmer.
Thanks everyone I'll attempt to locate someone local with a Flashcal Programmer.. And no it's not legal here in MO to run full tint, helps when your a police officer tho haha ;)
i'm guessing tho that you can't use someone else's Flashcal because it will be programmed to that specific jeep :banghead:
Think the dealer could/would do it?
