Since I have not had the chance yet to really do any real off-roading, will be coming up end of the month...
When I installed my 2" spacer lift, I noticed it was real close to putting tension on the ABS cable in the front while getting the springs back in. Does anyone know if an extension is available to add some length to this wire or is this even a real problem. Brake line seemed to still have a decent amount of slack.
Thinking about getting a set of discos but don't want to rip up any wiring. Guess I don't fully understand how much articulation this will give me and want to get some education before changing things I don't completely understand.
Thanks
You should be able to reroute your abs easy. Just un fasten from the clips holding up and zip tie the abs wire to your brake line. You shouldn't even need to disconnect the abs to do it.
