Trying to make this a specific discussion as opposed to the millions of "what lift and tires should I get" threads.
I'll start it, looking for others to add to it.
By leveling kit, I mean a spacer lift that puts a puck between the coil spring and the mount, reusing the stock springs and shocks, and that gives a little more boost to the front than the rear to even out the factory rake. By 2.5" lift, I mean replacement springs and shocks that are advertised as producing that much lift despite usually providing a little more in real life.
Leveling Kit with 33's
Pros:
Significantly cheaper
Easier to install
Easier to revert back to stock
Will not require any other components like exhaust spacers or trackbar mounts
Impact on MPG and on road driveability will be less
No need to regear
Can use factory wheels with spacers
Cons:
Less ground clearance
Reduced articulation
Less aggressive appearance
2.5" Lift with 35's:
Pros:
More ground clearance
More articulation
More aggressive appearance
Depending on kit, components will likely be substantially stronger than stock
Cons:
More expensive (more parts included)
Somewhat harder to install
Somewhat harder to revert back to stock
Greater impact on MPG and on road driveability
Requires new wheels
Will likely need to regear if axles are 3.21's
Pros:
Easier to install
No need to regear
Cons:
Pros:
More articulation
Cons:
Requires new wheels
