i recently found after replacing my oil pan gasket that my leak that i thought was coming from my oil pan really wasnt my issue, none the less i found it leaking from my distrubter and running down the oil pan gasket does anyone have any idea what might cause it to leak from there. the distributer works fine just moves alittle. Thanks!!:punk:
I haven't had mine apart for any reason but on the old distributors back in the day they had a little flat gasket that went between the block and the distributor. Hope it helps ya.
