1 - 9 of 9 Posts
Commercial Member
I understand the basics (lefty loosey, righty tight) and have access to a garage with a lift/special tools.
Can I install a teraflex 2.5 inch lift? I'm reading about the death wobble and its making me a bit nervous.
Was just going to pick up the lift with shocks. Anything else? This is going to save me about 500 in labor.
It looks like its plug and play and I don't think i need to cut anything or drill holes.
If you're mechanically inclined, pay attention to detail, and can follow instructions, and you have the right tools, you shouldn't have any trouble. A second set of hands might help.
My wife and I installed my lift on the floor of the garage using floor jacks and jack stands. No air tools, but I do have a battery powered impact wrench that was a life saver.
Took us about 8 hours to do it.
Sent from my SM-T550 using Tapatalk
DIY.
you'll then have gained knowledge should you have to trouble shoot any issues or perform future repairs, not to mention potential trail repairs.
Easy lift to install! DIY! Learn the ins and outs of your suspension
Keep an eye on brake lines when doing the front, and tip for getting the front springs in- jack up the opposite side your are working on when the axle is at full drop. Doing this will allow the side you are working on to drop a touch more and the axle will swing over a bit giving you more wiggle room to gt the front in
Geo correction brackets take care of the "wandering" feeling from what I have heard of those that did not put them on. I had them installed with the left.
Exhaust spacers.
https://www.youtube.com/watch?v=s2CQD68LHSg
After the install the rear axle was about an inch to the drivers side. A adj rear trackbar took care of that for me. The front was around 1/16th.
From what I have gathered, you also want to torque everything with the tires on ground.
Definitely DIY. You'll be glad you did.
Commercial Member
Exhaust spacers.
http://www.youtube.com/watch?v=s2CQD68LHSg
I was looking at the Teraflex 2.5 without shocks but adding the Rancho Shocks mainly because it was the recommended setup on one of the stickys. Also, it seemed to be plug and play, without any cutting or drilling. Appreciate the comments I'll take a look at the geo brackets and spacers. Seems the more I dig the more parts I need.
1 - 9 of 9 Posts
