I will be installing 10 LED pods on my JK but know very little about what is needed. I'm putting 2 in each wheel well and 2 under the front end. Each POD is 12V 1.4W. What is the best way to do this and what else will I need? (All in series, all parallel, each pair in series but parallel to the other pairs?) Do I need a relay or resistors or just wire the switch strait to the battery? Like I said I'm electrically illiterate.
Any help is appreciated. Thanks!
These are the lights I'm using: Waterproof 28W 7000K 1200LM 80x5050 SMD LED White Light Strip (DC 12V) - Free Shipping - DealExtreme
RokShots — High Beam Offroad
These are the LED's that I am using.
Because of the touchy electrical system in our JK's, I run all lights through a relay that is controlled via a switch on my A pillar. I will be running one in each wheel well as well as one under the middle of each side. I will be running a positive from the relay down each side of the Jeep, basically creating 2 daisy chains and grounding directly to the body.
