1 - 20 of 38 Posts
I have a 97 sahara 4.0 so I usually fill up wen my light comes on or wen it hit the red line and I pump 15-16 gals I think I have a 19gal tank from wht I understand u have and option between a 19 or 15 is this right
do this! Find out for sure! I did this this morning. This will tell everything you wanna know! gas tank, gear ratio, what front and rear axle, ect... Contact Jeep
in 1999 a 19 gal was standard. but from the sounds of it you do. i fell up when the light comes on and i pump 14 gal.
You would most likely have a 19 gallon, email jeep they respond quite quickly. If you're filling up 15-16 you are going to have the 19 gallon. Emailing jeep is nice because you get to figure out all your gearing and any other fun features you didn't know are on your tj
My TJ is a 2003.It clearly states in my owners manual that my tank is 19 gallons.I know changes were made in 2003,but the tank should be the same,I would imagine.
So I'm thinking I'm going to do that what do u send them your vin? And if I do have a 19 gal tank will tht effect a gas tank skid plate size since mine came wit one but not installed yet
in 1999 19 gal became standard. there where 14 and 19 gal tanks before 1999
In 1999 a 19 gallon tank became standard. All you do to get the build sheet is fill in your name, address, and contact info, then the last 8 of the VIN and mileage. I'm not sure if it being a 19 would affect the gas tank skid that you have. I'm guessing your skid would just bolt right up
just do what has red star next to it. last 8 digits of your vin your info. They send you an email telling you about your jeep. I got mine in about 20 min
This is what mine said:
Dear Travis:
Thank you for contacting the Jeep Customer Assistance Center.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
*K5 Cloth High-Back Bucket Seats
-AZ Agate
AACP Convenience Group I
AAS Tire & Wheel Group - 30"
ADCP Convenience Group
ADHP Heavy Duty Electrical Group
AEM Dual Top Group
APAS Monotone Paint
A68P 4.0L Eng(ERH)/5Spd M/T Nv3550(DDD)
BAUP 117 Amp Alternator
BCEP 600 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CADP High Back Bucket Seats
CAGP Easy Access Passenger Seat
CDBS Reclining Front Seats
CFMS Rear Folding Seat
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKES Front Seat Area Carpet
CKFS Rear Seat/Wheelhouse/Cargo Carpet
CKTS Cargo Tie Down Loops
CLC Front Floor Mats
CLSS Sport Bar w/Rear Padding
CUFP Full Length Floor Console
DBBC All Manual Transmissions
DDD 5-Speed HD Manual Transmission
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRKP Dana 44/226MM Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
ERH 4.0L I6 Power Tech Engine
GBBS Tinted Windshield Glass
GCBP Front Door Tinted Glass
GCD Deep Tint Sunscreen Windows
GCFP Full Metal Doors w/Roll-up Windows
GFAP Rear Window Defroster
GRVP Left Manual Mirror
GSVP Right Manual Mirror
GTVS Swing-Away Mirrors
GVAC All Vehicles W/O Power Mirrors
HAA Air Conditioning
JAYS Instrument Cluster w/Tach
JCDS 100 MPH Primary Speedometer
JHAP Var Intermittent Windshield Wipers
JHBP Rear Window Wiper/Washer
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKAS Locking Glove Box
KFRS STRIPE/BADGE/MOLDING/COLOR
KWRS STRIPE/BADGE/MOLDING/COLOR
KXRS STRIPE/BADGE/MOLDING/COLOR
KYRP STRIPE/BADGE/MOLDING/COLOR
K3ZS STRIPE/BADGE/MOLDING/COLOR
LAPP Shift Indicator Warning Lamp
LBBP Courtesy Lamps
LCDP Map/Dome Reading Lamps
LDAP Underhood Lamp
LMAS Halogen Headlamps
LNJ Fog Lamps
LPSS CHMSL Lamp
MBAS Painted Front Bumper
MB5S Black Rear Bumper
MCHS Bumper Extensions
MFPS Chrome Headlamp Bezels
MFRS Black Front Frame Overlay
MFTS Body Color Grille
MRJ Bodyside Side Steps
MWBS Sport Bar w/Side Padding
NAA Federal Emissions
NBKS EVAP Control System
NF1S 19 Gallon Fuel Tank
NHM Speed Control
PYHA Solar Yellow Clear Coat
QYHS Solar Yellow Clear Coat
RAAC All Radio Equipped Vehicles
RBR AM/FM Compact Disc Radio
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCGP Leather Wrapped Steering Wheel
SDUP Heavy Duty Suspension w/Gas Shocks
SHAS Front Stabilizer Bar
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBP Full Size Spare Tire
TBRS Outside Tire Carrier
TUSP 30X9.50R15LTB Wrangler OWL A/T Tires
TZAS Goodyear Brand Tires
VJXP Black Easy Folding Soft Top
VKXA Black Hard Top
WJXP 15X8.0 "CANYON" Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XCYS Delete Remote Start System
XEES Fuel Tank Skid Plate Shield
XEFS Transfer Case Skid Plate Shield
XEW 2 Front & 1 Rear Tow Hooks
XJFS Tethered Fuel Filler Cap
XPFS Protective Coating and Remover
Thanks again for your email.
Sincerely,
Josh
I did the build sheet thing everyone is talking about this morning......
It confirmed a lot of things I already new about my '98 sport (19 gallon tank being one of them) and filled me in on a few things I didn't know.......
It was a simple process.
TjWranglerMan said:
Is it on jeep.com or whts the email address?
I believe TJSpeed has a link to it on his first post in this thread, if not google "jeep vin build sheet" that's what I did
I had a 19 gal till my daughter made it into a 17.5 gal or so. I guess it's time to buy that skid plate I been putting off.
I notice that with my jeep. I go to gas station and it only fill up to 15 gal max. I even drove till my gas gauge was really on E then i want to get gas an only went a little past 15 gal. so im going to go to that jeep site and get the build sheet.
I've got a 19 gal tank (had a buddy run the code on my tank a few years ago and confirmed it with the build sheet this morning) and even though I coulda sworn I was on fumes a few times I've never been able to get more than 16 g's in mine.
1 - 20 of 38 Posts
