Hey guys, do i have a SYE??
ok i thought so. I swapped in a Ford 8.8 and used the spicer conversion and it bolted right up. I get vibrations on the road, so i was just making sure. It was on the Jeep when i bought it several years ago.
Thanks.
The dead giveaway is the slip yoke has been moved from inside the transfer case, into the driveshaft. When you swapped the 8.8 in did you set your pinion angle?
i don't know, had a buddy helped me that knew what he was doing. I mainly did the "ok where do i cut" and "i'll go get the tools"........lol
get a picture from the side where you can see the pinion going to the driveshaft going to the transfer case
