After my lengthy posting about all of the different things I’ve tried to get my 98 TJ running right
I replaced the upstream O2 sensor. The 6cylinder 4.0L ran great without the sensor connected
but now with the new one in place and codes cleared it hiccups around 30-35 mph. This only happens after stopping at the gas station filling up and restarting. Until I stopped it was fine. I’ve already wrapped the injectors and fuel rail in insulation (Heat soak issue prevention ). Could it be some residual gunk from the Seafoam treatment? Or can I head fake the computer and eliminate the
O2 sensor and just let it run rich but good?
I previously posted the 15 or so things I’ve already don.
Any ideas? Thanks
You should find and fix the problem running without o2 sensor is NOT the solution
Not just illegal but system is designed to modulate mixture based on sensor feedback to make it run properly
You problem is NOT due to connection of functional oxygen sensor
Check freeze frame stared data
Any ideas on how to find the problem ? I only have a simple ODB2 scanner
i would love to find and solve the problem, I’m very uptight about having things done the right way but I can live with a way to fake out the computer If there is a way to do it
any help would be great...thank...joe
If you are really uptight about doing things right, then you shouldn't be looking to bypass the PCM and omit the O2 sensor.
