I am told that I need to buy a new fuel tank because a component on my fuel tank has a crack in it and is leaking air.
I believe it is the on-board refueling vapor recovery (ORVR) system. I have attached a picture of a fuel tank showing the part.
Has anyone had success in replacing this part and not buying a whole new fuel tank? Or is it not possible to just replace the cracked component?
Jeeper
First off welcome to the forum. And I think those valves are molded into the tank.If so then you would need a tank.
There are sites where you can download the factory shop manual. I would look there. Search this forum for the name of the Jeep website with the downloads. I can't believe I didn't keep that link.
I had my tank out a couple times and never paid any attention to that part.
Might be possible to repair the crack
You might also search eBay. I found two tanks for 2003-4 TJ but that fitting is different on them.
Yes. Any component that affects the Emissions standards will require replacing, but may not have to be new. This leak will strike a code (Fuel Cap), if it isn't already.
Where exactly is the crack ? Maybe it is in the hose elbow. I would drop the tank and inpsect for yourself. Then you can decide what to do.
