Do you screw in your freedom panels or just do the other connections
  • I always screw in the freedom Panel
    Votes: 76 62.8%
  • Only when I feel like it
    Votes: 17 14.0%
  • Never. I never use them.
    Votes: 28 23.1%
1 - 20 of 43 Posts
So I am curious as to whether people are actually screwing in their freedom panels, or are they not using them?
Scott
Traditionally, I did not.
Seasonally though I am using the Sunrider top which utilizes them, so when I put the Freedom tops back on again, it was easier to put them back in again for storage.
Grumpy Old Guy
I do. I live in a downtown with pavers everywhere. It helps reduce the amount of vibrational noise created in the roof.
I did before I added the sun screen mesh which has bungees going through the holes.
Grooving With A Pict
Probably in your center console.
No, I think they're in a box with some other take-off parts that I've accumulated. I never run in golf cart mode, so I don't need them. Have had my hardtop off and on a dozen times at least, and no issues with leakage or misaligment. I remember when the Jeep was new, and they were still installed, I had some leakage issues if I went through a high pressure wash. Just ran it through one this morning on the way to work and still no leakage issues. :)
I have typically not put mine back in since the first year I had it and never had an issue.
If you decide to use them, I will caution you the some have reported water leaks caused by overtightening those screws.
I keep them in, but loose - just tight enough to not rattle. Too tight causes leaks.
Reactions: king_kong
I screw mine in.. It only takes a minute or so. But I rarely remove/replace my freedom panels.
I only take the panels and hard top off once a year (in the spring) in order to install my soft top, and then I don't put them back on until the late fall. Screwing them back in once a year in the fall is no big deal.
Only realized recently I didn't need them as I forgot to put them in...They are on now for the Winter months since I won't be using them, but come warmer weather I won't use them.
Always screw mine in.
“Never. I never use them.”
As in “I never use the screws” or “I never use the freedom panel” ?
Like other have posted. If mine are in and tighten down my panels leak if I run through the car wash. Remove them and no leaking.
Mine are the way God (ok, Jeep) made it. :D
I haven’t screwed them down in years on my wife’s jku but if I don’t screw them done on my jk I can hear them clunk on hard bumps so I keep them screwed down when I’m not removing them frequently.
1 - 20 of 43 Posts
