1 - 10 of 10 Posts
Howdy,
I installed the TF leveling kit on my 12 Sport. My question is, does the passenger side (left pic) sway bar link look correct? The angle looks off to me, but then again, I'm a newbie.
I would move it on the other side of the bracket. it should be mounted on the inside of the lower bracket not outside.
i'm back
I have the same set up. If you want to make those into quick discos, TF sells a smooth 3/4" bolt for $15 each, that goes on the axle mount and all you have to do is tap out the bushing from the lower part of the link so the new 3/4" smooth bolt slides in. And get a retaining pin from HomeDepot. Much better than paying over $150.
i'm back
1 - 10 of 10 Posts
