Originally Posted by 4racer
This past summer, bought a 2003 TJ Wrangler, with a hard-top soft-top, took the hard-top off, took the doors off for the summer and the dome lights stayed on. I went to the fuse box removed the 10amp fuse for accessories, the dome light went out. I went to put the hard-top back on with the doors, put the 10amp fuse back in and now my dome light stays on even with doors closed. Does anyone know why my dome light stays on? Am I doing something wrong? Would like to have my dome light working properly if I can. If anyone has any suggestions, I would love to hear from you.
Thanks 4racer
Couple things come to mind. Did you turn the switch on the turn signal stalk to the position where the dome lights come one and stay on? Did you hook the connectors back up on both doors when you put your doors back on?
I'm thinkin you have your switch turned on on the column signal stalk as stated....
