1 - 1 of 1 Posts
So with the control arms they supply M10 bolts and nuts plus washers for the uppers
Bolts are 10.9
Should be good to about 82Nm
See page 6
http://www.thomsonrail.com/Technical Resources/A short guide to metric nuts and bolts.pdf
Factory spec on those bolts is 55ft lb which is just under 75 Nm (below the82Nm) so good to go
BUT
The nuts they supply are stamped 8 designed for 8.8 strength bolts rated to
57.3 Nm which is a hair over 43 ft lbs
Houston we have a problem
The craptastic nuts fail short of factory torque and fail by threads stripping inside nut so will not tighten to spec and will not come off
So now you gotta grind off nut or bolt head
Thanks a bunch metalcloak
Back to factory nuts and almost an hour wasted
1 - 1 of 1 Posts
