Hi- (full) door handle is hard to open- needs a lube job. Anyone have any luck spraying the lock assembly from the outside without removing the interior door panel? Seems taking off door panel will be a pita. Thanks
Dont know about the handle but the door panel is actually pretty easy to get off. Just gotta take off the window crank with a small pick, few bolts along bottom and back edge, and the door grab handle. Then gently pull up as not to break the clips holding it on.
