When trying to get the door off don't just try to pull up on it. Make sure you take the door strap off and open the door all the way and as you're pulling up move the door back and forth a couple feet.Thanks for the info everyone, I messed with it quite a bit last night and you all are right, the nuts are gone. I got one loose last night and hit the other with more wd-40, now I only got one that is really stuck and will try to get it loose tonight. Saturday I put everything I had into lifting up on the door and it didn't budge which is why I thought that little cylinder above the threads needed to be loosened. First time taking the doors off and didn't want to bugger anything up.
GiggityNut up inside the hinge barrel
