1 - 14 of 14 Posts
I have a few guide pins for help installing your door.
They thread onto the door pin.
I have a few different lengths
30mm 40mm 50mm
There steel and have one flat on the side for a wrench if you need to tighten or loosen them.
Asking 15 shipped for 2
Or 22 shipped for 4
What model/brand? I'm interested
Sent from my SM-T113 using Tapatalk
What length do you recommend? Do they come off after the doors are on? If so, why would you need 4? I I've not taken my doors off yet, but I saw these apparatuses mentioned in a forum so I am interested
Yes they come off after the doors are back on or if you wanted to paint them and leave them on also.
It's up to you.
And if the doors are heavy for you the longer ones would be better imo because it will enter the hinge quickly.
And you can use 8 if you wanted.
Two per door on a 4 door.
I would suggest a little longer one on the top then on the bottom hinge.
Thx hopefully this helps.
Hello everyone. These are an awesome edition to your ride for half the cost!!! No need to spend $40 when you can get the same thing for $20. I just left them on my doors and they guide my doors back on with ease!!!
Is there any reason to get shorter pins? I would assume the longer the better
I got the middle set and they are perfect.
1 - 14 of 14 Posts
