I was trying to put on some diamond plated door covers for my 91 YJ 1/2 doors when i rounded out all but four of the door hinge bolts. I was able to get the ones on the top hinge out by taking out the sliding plate inside the door out. Is there any way to take out the bottom one as well?
Thanks,
Steven
Rock-Rubber
I stripped one once. Used a Dremel with a cut wheel to cut the head off when the extractor bit broke off. Then drilled it out and used a chisel to crack the metal. Then pulled the pieces out. Or some horrific story like that. I learned to be alot more careful now.
