It's the black plastic curved piece at the top of each door that the top of the door seats against when you close the door. Each one is held on to the roll bar by two large knob-looking hand screws. That piece can be removed if you aren't going to be running with doors.From a newbie, what are the door surrounds? No laughing. I'm already laughing at myself.
Thank you, I appreciate it.It's the black plastic curved piece at the top of each door that the top of the door seats against when you close the door. Each one is held on to the roll bar by two large knob-looking hand screws. That piece can be removed if you aren't going to be running with doors.
I only removed mine once. One of the knobs was missing from the original owner so you had to take that one loose with a pair of pliers, so it was kind of a pain, so I normally left mine on
Do you still have your mucket seals?Mine rattle around at the bottom like a son of a [email protected]@@@
The tapping noise is beyond annoying. Need to get some kind of soft sealant to glue to the bottom so I don't hear the damn vibrating ticking noise
at the bottom of the door surround where it meets the jeep there is supposed to be a black rubber gasket. You can pick these up online and they will stop the vibrating and the noise. They're called Mucket seals. http://m.quadratec.com/products/product.php?pid=13022+56Mine rattle around at the bottom like a son of a [email protected]@@@ The tapping noise is beyond annoying. Need to get some kind of soft sealant to glue to the bottom so I don't hear the damn vibrating ticking noise
$20 for .05 worth of molded rubber. I'll make my own from rubber from the hardware store thank you very much.at the bottom of the door surround where it meets the jeep there is supposed to be a black rubber gasket. You can pick these up online and they will stop the vibrating and the noise. They're called Mucket seals. Upper Passenger Side Rear Door Frame Mucket Seal | Jeep Parts and Accessories | Quadratec
Ahh yes mine must be gone! At least on my drivers side.. That's the noisy one. 20$ does seem a bit high.. May look into a DIY fix before I buy one.Do you still have your mucket seals?
Haha I know, I probably would too, all the more reason not to lose the ones you've got though.$20 for .05 worth of molded rubber. I'll make my own from rubber from the hardware store thank you very much.![]()
Very different Rims, what are they if you don't mind me asking? ThanksI take everything off including the bars from the rollbar to the Windshield frame. I don't want to see anything over my head.
Sometimes, I drop the Windshield too. This is awesome! (but wear goggles!)
