Mine ripped out, by the wires. Drivers side. Its starting to annoy me that the lights do not come on when I open my door. How can i replace it and is it possible to find the replacement local?
Thanks in advance.
Did the wires themselves break or did they pull out of the part of the wire harness that plugs together. If it is just the wires, I would just splice them back together with crimp connectors. If it is the plug, you may be able to buy that at the dealer. If not, check out one of those salvage yards where you can go out and pull the part that you need.
The wires that connect in to the plug ripped. they didnt just pull out. I will ask a friend thats good with wiring.
Thanks @Freedom_jk
