Hes got an east coast YJ.. Them doors aint budgin' without some helpCan you slide them up a little? When mine get a little tough to get off, I slide them up a bit, WD40 the hinge pins (which are attached to the door side of the hinge), let them slide back in, open and close a couple times. They come right off then.![]()
OMGROFLMAO?I beat mine halfway to death before I realized there were nuts on them. :chair:
I'm sorry, you just set yourself up so well for that one, I couldn't resist!!!Hey, I never said I was smart. I gots that fourf greyed edjumucayshun.
bad idea. Dont do that unless you have to. If you jack it up in the wrong spot, and jack it up too high, you WILL bend your door pins or break off your hinges. Bend your door pins, and you will NEVER get that door in right.Use a jack. Put a board between the jack and door and gently convince it to come out![]()
QFMFT!!!Your doors are much heavier than you think they are.
QFMFT!!!
Nevermind. The Urban Dictionary is my friend.QFMFT? Never seen this one before.![]()
