Periodically, when I turn the steering wheel in one direction to full lock and drive, when I bring the wheel back to what should be center it’s off a few degrees.
For example, last weekend my steering wheel was exactly centered so that the top was at twelve o’clock. While I was out I had to lock to the wheel all the way to the left and drive out of a spot. When I brought the steering wheel back to center, the top was at about ten o’clock.
This happens in either direction (turn left, off to the left; turn right, off to the right). I’ve checked the sleeve on the drag link and it’s still tight and torqued to the recommended 20ft/lbs.
Any thoughts or suggestions?
Specs:
2001 Sahara
3" Lift
Metalcloak Trackbar (brand new, everything tight)
107k miles
Specs:
2001 Sahara
3" Lift
107k miles
