So I'm doing my inspection under my jku with 23k miles witch I do about once a month and I see one of the rubber seals on my drag link leaking grease out .. So should I up grade to a heavy duty Tera flex drag link? Or is it fine?
Thanks for any feedback!
If it's leaking, check for rips or tears in the rubber boots. If you don't find any, who ever did the last lube job may have forced too much grease into them. Unless of course you are eager to replace them with after market parts.
the OEM rod ends have no grease fittings, so nobody ever forced grease out. if the end isnt worn, run it till it is.
RETIRED MODERATER
^^^If it is original and still under warranty, then have your Dealer replace it!!!!!!
