So I have a sue and Tom woods drive shaft installed about a month ago so to day I took the tc drop out and now I have drive line vibs around 50 to 55 but mainly when I let out of the gas any suggestions
Didn't readjust pinion because the angle looked better without the drop kit. With the drop kit it was in a straight line without its slightly down. Should I move it back straight?
remember that the slight down angle (front to back) is to accommodate for the weight of the passengers when on the vehicle. basically when you get in the car the added weight should even it out a bit more pushing the center of the car lower to the ground there by decreasing the angle. by making it flush, with no added weight in the car the dl will probably be in a slight upwards angle. always rememeber to accommodate for the added weight.
