  • Hey everyone! Enter your ride HERE to be a part of MAY's Ride of the Month Challenge!
2012 COD MW3 - None of the drivers side marker lights are working. Is there something I can look for before taking it into the dealership ?
Naturally the first thing that comes to mind is a fuse. Other than that the dealer.
Just driver's side? There's a harness plug up under your fender, near the front bumper (I think...been awhile, and I've got an aftermarket setup). See if it's loose.
If not, disconnect your battery, wait about 10 mins, hook it back up and see if that does anything.
Yes. Just drivers side. Only 2500 miles.
x-2 sure sounds like a bad connection or ground...Just for the hell of it,.... have you checked the bulbs?
Check the fuse and then disconnect battery for about ten minutes. If that doesn't do it, then a trip to the deal is in order.
Was the fuse. It happened after towing my trailer. It must have a short-just what I wanted-another project.
