is there a diff in yj and tj 4.0 driveshafts.got my tcase for my 4.0 swap and it has a sye on it.the guy has the front drivesgaft out of a yj and the rear sye driveshaft out of a tj.will this work.
it should as long as the drive shafts have the correct u-joint and proper length. u-joints should be the 1310. just measure the outside of u-joint and inside of yoke.
Tips from the Beas
You will need to make sure the splines on the driveshaft and the final drive line out of the trans match up. But I don't see why these won't work. TJ, YJ, XJ, ZJ .... all this means is body style and different motors. Your older Jeeps 90-97 either had an AX-5(2.5L) or the AX-15(4.0l + 4.2L). Most of your Jeeps are basically the same as far as parts go. Hope this will help. :punk:
ive also got front and rear 4.2 driveshafts. will these work
