1 - 9 of 9 Posts
How long can one drive with a clanking front drive shaft?
I found out today, the noise I've been hearing from as long as I can remember (since I bought the car I believe back in May '11) is my front drive shaft, and they recommend a rebuild -- quoting around $600. However, after just dropping $1,200 to have the onboard computer (PCM) replaced, I opted not to. They said it was safe to drive, but be on the lookout if it gets worse.
I'm assuming rebuilding it would be far too complex for a novice such as myself. Anybody in the Mountain View/Sunnyvale area with a free weekend to teach a novice? ;)
Anyway, what's the best way to determine it's worn out its welcome, and rebuilt will be necessary?
*Edit: Oops, sorry. It's the front drive shaft in question.
The "drive train" consists of the engine, transmission, transfer case, front and rear drive shafts, front and rear differentials. You're going to have to narrow it down a bit.
Oh. Doh! Okay, it's says "Recommend front drive shaft rebuild" on my invoice. Sorry! I got "drivetrain" in my head somehow, and it kind of stuck. My apologies.
I would run without the front driveshaft until it can be replaced/rebuilt. There was a thread a few days ago where a dude's transfer case grenaded. I wouldn't take a chance if it were me.
Let me get this straight. First, your mechanic tells you that a part that seldom goes bad (ecm) needs to be replaced and charges you $1200. Did you know that you can buy them new for less than $500? Now, he tells you he'll rebuild your front driveshaft for almost twice the cost of a new shaft. You need to run very far away from that shop and never go back.
Error codes were:
P0700 - Trans Controller Fault; P1604 - PCM Internal Dual Port RAM Read/Write.
I actually got the codes from another dealer, and they told me "we don't do transmissions" so I had to take it another guy.
Part was $635. Labor was 480 for investigation (I didn't trust the first dealer's info; so I had this other dealer reinvestigate), and repair. The actual repair was nothing: only 1.6hrs. And the result: engine light no longer on.
Now, the PCM went bad as it appears it was tampered with previously: there was silicon on the connectors. They had to clean it off, initially having trouble making it work.
The $600 is what I'm rounding up. He said $500-$600 for them to do all the work: rebuild and replace. Looking online, front drive shafts are $500-$800 ?! Or am I just looking at the wrong item? This site lists it just over $800.
This is the switched mechanic. The first one didn't give me a good vibe, even after having nothing but 5 start reviews on Yelp. I didn't like him. This place 4, but gave me a better vibe. One 2 star said they do good work, but a little pricey. Eh. I rather have people I trust to get the job done right, than one who will give me the cheapest price.
Call the guys at Tatton's Driveshaft service. They'll build you a front driveshaft for under $300 shipped. I have one of their rear shafts in my Sahara and it functions as expected.
1 - 9 of 9 Posts
