Noob here. I searched the forum but only found answers for JK's. I bought a pair of Turbo 7 Inch Round Black Led Headlights with DRL off of Amazon for my 2006 LJ. The DRL have a dedicated white wire. I purchased a Fuse tap and ran both DRL wires to the fuse tap. My problem is that when the ignition is off, every fuse tap I use turns the DRL on, Radio, Fog Light, Power, etc.
Where can I get power under the hood for these DRL's? I just want them to come on when I start my Jeep.
Thanks.
The coil rail and each injector have an ignition on only plus 12 (plus each coil in rail and each injector has a pulsed ground controlled by PCM)
Course only use that to close a relay to switch power to your light so you do not add any significant amp draw to the coil rail or injector circuit
