want to drop the mount locations on the front and maybe rear arm. i have twisted ideas that the angle should be less (leveler with the ground), plus i am putting on a 2-3 inch lift that would make it worse. has anybody done this on a short arm?
There used to be kits to do just that...
HORRIBLE tho... piss poor ground clearance...
If you want to keep your arms "leveler" do a 1-2" lift and a 1.25" body lift...
Knows a couple things...
No reason nor benefit to trying to make the arm angles more level than they would be on the stock mounts.
like Gotta says, utilize the BL to need the least amount of suspension change to achieve the desired effect.
