Hey Everyone,
I have a 2013 Jeep Wrangler Unlimited Rubicon (just passed 60k miles) with a recurring error code P0128 that's driving me nuts. I have an Innova 3020d code reader.
This all started about 2 weeks ago. Right before my emissions test is due of course. I had an engine light error to replace the oil pressure sensor switch, which I have done and that code is clear.
After that I get the error P0128, which is one off three things it says....
1. Low engine coolant level - no
2. Leaky or stuck open thermostat - maybe? but no signs of leak or over heatingg
3. Faulty cooling fan - doubtful
4. Faulty ECT - replaced last week
5. Faulty intake air temp sensor IAT - maybe?
I am running great. My dashboard temp gauge is functioning normal, no hot readings after driving to Heber (140 miles) and back this weekend or any other time.
Does anyone have any suggestions as to what the issue is? I can't get my emissions test til I fix it and I am running out of time. If I clear it then I have to go through the drive cycle before I can get it tested and every time it does that the code is back.
Thank you in advance for any help.
Low engine coolant level Leaking or stuck open thermostat (likely) Faulty cooling fan (running too much) Faulty coolant temperature (ECT) sensor Faulty intake air temperature (IAT) sensor
Read more at: https://www.obd-codes.com/p0128
Copyright OBD-Codes.com
