1 - 20 of 37 Posts
Custom JEEP Decals
Hey all. My idea is this: mount 2 downfiring 10" DVC Polk subs in a custom sealed enclosure behind my rear seat. I wanted to put the amps (Alpine m500 and a 2 channel) below the enclosure mounted to the tub. I plan to mount the enclosure on sliders (slide out of trunk), so that i can pull the subs out if need be...any major concerns/issues with this? Ill try to find some pics to show you what i want to do.
Oh and im gonna wire them to get 4ohms load on the amp.
Shouldn't have any issues. Just measure and re-measure while in the design/building process. Make sure you calculate your volume correctly and make sure you have enough room to fit the subs on the face while keeping them far enough from the floor to allow for the xmax travel.
I'm going to do the same but with a single 12" ported.
Custom JEEP Decals
what type of sub are you using?
Custom JEEP Decals
You may end up running into some serious volume issues if you plan to keep the amps under the box. I would put the amps under the rear seat as this will allow you to have more space in the rear "trunk" area for the box and proper volume required. Also your gas tank is right below the trunk area and you need to be VERY sure that you dont drill into it while mounting anything. As for the subs on a slider, it should work nicely just remember if it is easy for you to take them out then it will be easy for a thief. I hate saying things like that cause most people will never have an issue but its something to consider. I currently have 1 kicker cvT the thin mount ones in a sealed box behind my seat, I mounted it to the tailgate so I could secure it without the gas tank issue. Good luck and enjoy!
Custom JEEP Decals
Yeah I knew i needed to make an enclosure big enough. each sub is rated at .66 cu. ft. so i need 1.32 cu. ft. I worked out the math to be over 1.5 cu. ft. And the sliders would be situated so that they slide out the trunk. When i get down to actually sizing everything up I will revisit the theft potential.
it would have to be one big amp to make any type of change to the sound. mount the amps were they can stay dry and out of sight and have ventilation to it doesn't over heat.
I was thinking more along the lines of dimensions and space needed. for example:
2" tall amp
2" minimum clearance for downfiring subs
thats already 4" up from the floor and theres only like 14" to the top of the tailgate if I remember correctly. also the rear seat tapers back making the clearance at the top of the box only 9" or so. Just going to have to be a really tall box for that to happen properly.
These measurements are probably not "Spot" on since its been a long time since I did the planning for my box so dont go building off my memory but just wanted to give a heads up since this is something I have been thru already.
Custom JEEP Decals
Discussion Starter · #13 ·
i really appreciate the advice! ill crunch the numbers tomorrow on the box. right now im working out the amps/subs. looks like ill be running the subs with dual m500s. (picking up another one tomorrow).
My original idea for amp placement was on the sidewall of the tub in the trunk area. i would lose width, but preserve height. and yes, ill have 3 amps total. might mount the 2channel amp on the tailgate
lilyeller. when you said volume i thought your were talking about sound not space.
Custom JEEP Decals
Discussion Starter · #15 ·
I've read different things about mounting the amp directly to the enclosure, it makes sense not to because of the vibrations. But it seems like everyone is doing it!! If I can mount them safely to the enclosure, it would make my life a lot easier, id put them on the rear, facing the trunk
"Technically speaking" its not good to mount the amp to the box but thats how I have done many systems in my own cars. The only casualty I have had is when I had 4 12's and some Audiobahn amps pushing them. The fan on both the amps fell out of the amp and overheated one of them. it rattled right off. However, that was likely to happen anyways cause those are CHEAP amps lol. so call it what you may but I would say you only have a limited space and do what you need to get it all to fit. I would certainly mount the amp to the box again if I had to. But for me under the rear seat works fine cause they dont get rained on. And what little water that does get inside when the top is off goes right under the amps cause they are lifted off the true bottom of the tub by the little ridges that are built into the floorboard.
^^ What he said.
Really you're not likely to damage the amp by having it mounted on the enclosure. Ideally you'd have it mounted elsewhere but it's not likely to shorten the amps life by mounting it there.
Just remember to compensate for the size of the trunk lock and the thickness of the wood you're using when your calculating the size of your box!
Custom JEEP Decals
Discussion Starter · #19 ·
i got the build underway. ripped out the rest of the carpet, took out my instatrunk, unhooked my amps,thought about the location of the (3) amps. i think ive decide on mounting one of my mono amps to the right side of the tub next to the enclosure and have the other two mounted next to each other on the tailgate. i have 13" sliders that will bring the enclosure all the way out the back of my tailgate if/when i want to remove the speakers. what do you all think?
1 - 20 of 37 Posts
