I just installed a new dual battery set-up in my 2012 JK Rubicon. I get dash lights and it cranks, but will not start. Install called for taking out the fuse box, (tipm), (which I did not want to do.) Oh... and one small detail: While I had the fuse box out, my dumb-ass dropped it on the asphalt driveway..
Could this cause the failure of the Jeep to start?
I've kicked myself all around the house for being such a clumsy idiot.
(I've worked on my own stuff all my life (64 yo), and did it for a living for 10 years when a screwdriver and a feeler gauge did most tricks, so I am not a shade-tree idiot, just an idiot.)
Any help would be greatly appreciated!
I would start by Opening up the TIPM and make sure all the fuses and relays are seated properly....
Edit
I would also look at the fuel pump fuse..... Unfortunately the relay for that one is soldered right into a electronic board below the fuses. Good news is there is a way to by pass it:
http://www.verticalvisions.com/TIPM_cables.php
Yeah, I did that. Dropping the unit was the only variable outa whack. I was very careful to make all appropriate connections, etc.
When you put the key in and put it to the run (not start). do you here the fuel pump?
I would Also try and put back in the stock battery/clamps and see if she starts, just to rule out defective parts.
All is well, the beast runs. Nothing is more frustrating than completing work on a project, and it won't start, presumably due to some fumbling on my part.
Pulled the TIPM back out, and one of the connectors was not seated in the socket.
Thanks for the help. It's great to know that I can turn to this community for some help and answers in a time of panic.
