If I push the shift fork all the way towards the driver side am I in all time 4wd? Cause I've done that now whenever I shift the transfer case to 4hi or 4lo and drive it makes some real loud noises what could this be? Please help.
Fork toward the driver side will disconnect your passenger side outer shaft. You may not be pushing it far enough and the collar is grinding on the splines.
