1 - 12 of 12 Posts
They're not maintenance free.The outside of the bushings must be greased although not as often as the arms that have bushings with zerks but greased nonetheless. You must remove the arms from the Jeep, disassemble the bushings, apply grease and put them back. How often will depend on your driving habits, snow and mud will mess everything up quickly. At the very least follow their recommendation of once a year.
That’s also what I read in the installation instructions, but the description and also the video on the page with the arms leads you to believe otherwise. So that made me wonder what people actually do.
Photograph Font Rectangle Art Circle
Sleeve Font Sportswear Electric blue Polo shirt
What does “use of any other lubricant” mean. Is there a certain type of grease that must be used?
From their website:
Low Maintenance & Rebuildable...
Unlike typical Flex Joints, the Duroflex does not require replacing key parts every year like others...
But, when you do need to rebuild it, it is MetalCloak Easy!
Just pull out the Duroflex Bushing, clean it up, add some new Teflon impregnated, synthetic silicone grease. Reassemble.
Done.
Discussion Starter · #6 · (Edited)
Look at this Youtube by Metalcloak and especially read one of their comments:
"The joints are maintenance free and do not need to be re-lubed once installed. These instructions are for the guy who likes to take apart his suspension and clean up all the parts. If you do that or if you replace a bushings after several years, then you will apply a small amount of grease to the outside. The grease is Superlube and is available in most autoparts stores."
I'm guessing this is the stuff they use:
Pretty much maintenance free. I rebuilt my arms at the 4 year point, total waste of time and money. I was doing some cleanup and decided since I was in there I might as well rebuild them. All the bushing showed very little wear and still had grease in the joints. If you really flex your vehicle out a lot, do water crossings or play in the mud you mileage may very. But most of those 4 years where spent in wet Western Washington so normal wet weather is really not an issue. These is the stuff they use and was confirmed 12/4 with MetalCloak:
Reactions: AZDane and Leadnut
That's a relief :cool:
Watching and seeing the aftermarket trend of control arms go through its trends for almost 9 years now, Im very happy that I stuck with new OE. In the NJ salt and snow with freezing weather and blazing summers, Id imagine rebuilding arms more often is a necessity. And with every passing year I still find maintenance work to be fun but I rather do less of it with each of my vehicles. Especially with how busy life can be overall.
You just cant let the brine do any time on the undercarriage. We hit the local spray and go quite often here in Mercer Co and no issues. Unless we count salting when it is 50 out like our Gov likes to do.
Sent from my SAMSUNG-SM-G891A using Tapatalk
NJ with "blazing summers"? That's a good 1 :LOL:
  • Haha
Reactions: fourpointzero
1 - 12 of 12 Posts
