1 - 1 of 1 Posts
I bought a "frozen" Rubicon sway bar and EVO knob kit. Tore the E-Disco Rubicon swaybar apart. Got it all cleaned up (unfrozen). Installed the EVO knob. Swaybar locks and unlocks smoothly. However, the sides are not synched / locked together when the swaybar first starts to move. I'm able to move side A 1/4" or 1/2" before side B will start moving. It appears there is a small bit of play in the gears / collar combo. The front end feels a little looser since installing the "new" swaybar.
Stock height JKU that was just aligned, with stock length swaybar links.
Is the little bit of play between each side (in the gears / collar) normal and ok?
Thanks
1 - 1 of 1 Posts
