Just finished the install of the dirtworx tire carrier but I'll have to take pictures tomorrow as it is to dark out now. After priming it and painting it black it was ready to install. I used the included grade 8 hardware to mount it and drilled the 4 new holes needed in the rear cross member. I removed the 4 bolts on the rear of the gas tank skid to give myself some room and was able to get the top bolts in behind the tank but I couldn't contort my hand enough to get the lower two bolts in so I used the new bolts on the underside of the frame for the bumper mount instead. This left me with 6 bolts into the rear cross member and two in the bottom of the frame so it should be plenty strong. Next I slid the tire carrier over the spindle and tightened the allen bolt that holds it on. The latch is held on with 4 small bolts so i put that on and adjusted it so it latches tight. The latch itself functions similarly to vice grips and clicks shut and is very solid. I tried yanking on it and the latch was not going anywhere, very strong and rattle free design. The only thing left is to get some D-ring shackles to put on. I couldn't be happier with the quality of this bumper/tire carrier and for the price it can't be beat. I would recommend it to anyone who is looking for one.
