1 - 1 of 1 Posts
Hey All, found a bad ground that was causing the air compressor and all 4 oxigin sensors to fail. After fixing the ground everything works except for the warm/rear sensors. There is no voltage from the wires at the sensors. Will a new ECM fix this or is there a wire somewhere else that may cause just the rear sensors to have no power? Thanks!
1 - 1 of 1 Posts
